aeviaanah
I just purchased a new 15hp 4stroke from Bass Pro Shop. I was running the motor in a barrel and everything was running fine. I walked away for a minute and when I came back water was not pumping due to what i thought was the water level had dropped in barrel. Motor was idling and it couldn't have ran for more than 2 minutes although it could have only been a few seconds. I immediately shut it off and filled barrel with more water and fired motor back up. A bit more exhaust came out for a few seconds. I didn't notice an overheat smell or any excessive temps coming from motor. Everything seems to be running fine...water pump works, motor sounds fine.
I really don't know if I messed up badly or if I didn't do anything at all. Can these motors run for a bit without water? Water was in system and was idling before hand, is there stored water in motors to keep em cool for a few seconds? What if someone is running full throttle on the water and a blockage occurs, where is the protection? How tough are these motors?
What should I do? Should I check anything out to prevent further damage?
