ckr74
I put a OMC fuel tank in my boat a while back and it appears that the venting is not in the cap but by the fuel connector. I did some searching on this and the vent is basically a one way vent meaning it let's air in as fuel is used but won't let pressure escape. I think this is correct. Could a hole be drilled in the top of the tank to add a vent similar to the cap vents? Could the cap be vented? This thing builds a lot of pressure, so much that it leaks by the carb seat.
