Justincasei812
Good day all,
I have a new very used 1980 mercury 50 hp outboard that bogs down when I put it in gear. If I rev it up some before I put it in gear it will get past the bog point and runs fine other wise it stalls. I put in a new trigger, stator, power pack, rectifier, coils & spark plugs on it a couple of weeks ago due to no spark on 3 & 4. Figured it was better to change it all while I was doing it. The stator had both wires cut going to the rectifier so that had to be replaced either way. I don't know a lot about the boat as of now. I am thinking it may be the carbs but wouldn't it run bad at all speeds?
Justin
Justin
