Douglasdzaster
- Joined
- Sep 19, 2020
- Messages
- 780
- Reaction score
- 461
- Location
- Smithville,Texas
- LOCATION
- Smithville, Texas
Hello everyone, Been having trouble on line so this may be a double post.
My wonderful wife ask me to put together a complete list for finishing my boat in order of importance such as bunk etc. I’m listing and shopping so I have cost of everything.
I’m at the bottom of the hull now. I’ve found some that come with pigment so I can chose color and not have to paint over it. Now I’m cost comparing to Goop Coat it.
Which is a task to apply but I think I have away of mixing in batches.
What can I paint over it with that won’t kill the budget that won’t peel off because of friction?
Bottom boat paint for aluminum boats is costly but will it hold up better that say Rustoleum?
I’ll be painting the sides a little to up to the water line then start with an above the water line different color. I’m going for blue on the bottom and flat gray for the rest of the boat.
While I’m asking I’ll be painting the 40hp Yamaha as well. The head is still in good shape under the cowling it’s Yamaha blue. Previous owner painted the cowling and rest camouflage. The lower unit is almost all worn off and I noticed the scag looking like it has a little corrosion. Anode trim tab is in good shape but looks oxidized. I took it off a while Back and cleaned it up and put it back on. I’m going to go ahead and replace it and make sure where it mount is clean.
But I need to get some paint on it. Doesn’t have to be Yamaha. It could be gray with the boat or some other color that would go with it. Thought about separating the blue and gray with another color but can’t come up with anything that would work.
When it comes to picking paint colors I’m not allowed. My wife don’t want me near those color cards.![Face with tears of joy :joy: 😂](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f602.png)
I appreciate any input as always. Y’all have helped me so much. From me discovering it needs rebuilding when I found the corrosion to the new complete electrical system being done correctly. Which works great by the way and not a single sign of any corrosion. I keep it fuse block and switch panel clean and protected. Recently up graded that and tm batteries to lithium ion and took my 10 year old grandson out Saturday. After dark I flipped one the blue leads and I was told. Wow Gpa that is sick.
Wowed the little guy again when I lowered the big green light down in the water then plugged it in the switch panel and it glowed green all underneath the boat.
He was talking pictures and sending them to his mom.
Didn’t catch anything in the power plant lake we were on the cooler end instead of where the hot water discharge is. My Yamaha is waiting on a part we where trolling motor only
And this was safer with a 10 year old in the boat. But we had a lolot of fun and I taught him several things. He thought the way I put punch bait on a treble hook was smart. I told him I didn’t figure it out. I learned from someone else. He said just like I’m learning from you now.
Ok I’ll shut up now.. Sorry for rambling.
Again thanks for any suggestions about the paint.
