Blkrvrbart
- Joined
- Mar 30, 2018
- Messages
- 42
- Reaction score
- 0
More progress last night. Mostly reriveting what was loose. Definitely going with aluminum decking. Welded the bow damage.
lckstckn2smknbrls said:Silicone doesn't play nice with aluminum.
Thanks! I’ll check it out. Getting pretty close to that step.gatorglenn said:I will be using this, to replace my foam. It’s use by a lot of the boat racing community. And it can be sculpted to your needs in areas where drainage is a must. Then Iam spraying truck bed line from cans. On top so water won’t sit on it to eventually soak in and saturate. This was my problem. It is closed cell foam. And is 1.75 pounds per cubic feet. Same as what was in these Trackers. Good luck with your build.
I didn't see this until today.eshaw said:lckstckn2smknbrls said:Silicone doesn't play nice with aluminum.
Why is that?
lckstckn2smknbrls said:I didn't see this until today.eshaw said:lckstckn2smknbrls said:Silicone doesn't play nice with aluminum.
Why is that?
IIRC Silicone has an acid in it that can damage the aluminum. Loctite 2 in1 caulk is safe to use with aluminum.
ok what screws did you use in the floor. Iam having a hard time matching the ones that came out of my floor. ThanksBlkrvrbart said:More progress.
They are stainless steel lath head number 8 self drilling screws. When you get through the top plate you have to reverse the impact, strip out that hole and then drive the screw in tight. Everything drew down nice.gatorglenn said:ok what screws did you use in the floor. Iam having a hard time matching the ones that came out of my floor. ThanksBlkrvrbart said:More progress.
I am serious about stripping out the hole in the decking. As soon as you get through the decking material, before you cut into the framing, stop your drill( or driver) , REVERSE IT, and “strip out” the hole in the decking. After you do that, set your drill or driver to forward and tighten the screw down without stripping the hole in the framing or snapping off the screw. This will tighten down the decking to the framing without leaving a gap or breaking the screw. It takes less time and tools than predrilling. It’ll come easy by the fourth screw.gatorglenn said:Thanks, yea they are soft. Real easy to strip. Local Fastenal store, and but box store. Didn’t have any. They had the stainless steel coated ones. Didn’t want those because they will rust over time. And I do like the way they pull down. And disappear in the carpet Iam using.
