Rivet repair questions
nbaffaro
Lumberton, NC
I bought a boat in need of repair. It fit the budget so I went for it. The PO removed quite a few rivets and they need to be replaced. However not all of the holes are round. How do I go about fixing them.
Also, I can't find this answer anywhere. Does the air hammer go on the button head or does the bucking bar go on the button head?
Thanks
Nick
Galaxy SIII using Tapatalk 4 Beta
Depends on size of messed up holes, one way is to drill out the hole with larger bit and use a larger than normal rivet. I have always used the air hammer on head, but I also use a rivet set to match the button head.
If your just sealing the old holes you can have them welded, another way is to take a piece of aluminum and glue it over the hole with 3M 5200.
