For fastening 1/8" thick angle AL to 1/8" thick angle AL. What size rivets to use? I bought 3/16" by 1/4" long, but I'm wondering if I need to buy a little bit longer rivets?
Ringo Steele said:I used 3/16x1/2" rivets for most of mine. Be sure to use a rivet with a body length long enough that the bulb end can expand on the outside of your material to be fastened together. The longer rivet will fasten thinner material as well. Check a site such as rivetsonline.com for specifications on the thickness of material each rivet will securely fasten.
bcbouy said:i used close to 250 rivets,but i also went thru 3 drill bits and 2 saw blades.
PSG-1 said:First off, +1 to what bassblaster said about the Harbor Freight heavy duty rivet gun. 8) Great tool for the money, and it handles up to 1/4" rivets, where the rivet guns you buy at Home Depot for the same price, only handle 3/16". While many factory boats, such as my Triton, use 3/16 rivets for the floors, if you want a little more strength, 1/4" is the way to go.
As far as cutting, the good news with aluminum is that it's a soft enough material, virtually any tools that can be used to cut, or shape wood, can be used on aluminum with no problem. Regular wood blades can be used on recipro saws, and they will cut with no problem.
For a circular saw, try a Freud Diablo blade for cutting aluminum. They're red in color, and you can pick one up at Home Depot or Lowes.
They have a thinner kerf than regular circular saw blades, which means less resistance in the cut. Use the fine tooth blade for thin gage material, such as 1/8" and the coarse tooth for thick stuff like 1/4"
I've personally cut aluminum as thick as 3/8" with a Diablo blade.
Another great use for the circular saw with aluminum.....if you have to remove a lot of material by grinding, or cutting welds, provided you have a steady hand, and you're careful, you can use a circular saw like a portable milling machine. You want to rest the front end of the saw on the work, then, with the back end tilted up, bring it up to speed, and slowly bring the blade down until it touches the work. Then, slowly 'swipe' the saw across the surface, letting the teeth remove material as you make the movement. Each pass will take about 1/16" of material. This is a very fast, efficient means of milling down a surface of aluminum when the part can't be put on a mill. It's also a great way to save wear and tear on your grinder, and your grinding wheels.
BUT BE EXTREMELY CAREFUL when using a saw like this, all it takes is for one kick-back to occur, and it's bad news.
Regardless, when you're cutting aluminum with a miter saw or circular saw, you definitely want to wear long sleeves and a face shield, as well as safety glasses, as circular saws will throw hot shards of aluminum when cutting, the shards tend to stick to your skin and burn you. And definitely a pair of earmuffs or ear plugs, as it's also quite noisy. "Chop saws" that use abrasive blades can cut aluminum, but since it's an abrasive wheel, it will tend to heat and clog, like a grinding wheel. Best to stick with jig saws, recipro saws, circular saws, and miter saws.
Always bring the saw up to full RPM, and begin your cut slowly, to reduce the chance of a kick-back.
