cdustinc
When installing the solid rivets, how tight does the hole in which the rivet will go need to be? I ask because one hole I have to plug (where a bolt used to be) is just a little bigger than the 1/4" solid rivets I have. Will the rivet spread out enough to fill in the hole once it's whopped with a hammer? Will this be a problem?
