DPI
I wanted to post this dramatic picture of how well this stuff cleaned off years of stain from my Tracker. I think the previous owner never even washed this tin and after 13 years it had a lot of stains and oxidation.
I tried several different cleaners including compounds with my buffer. And nothing compares to this starbrite. You spray it and let it set for up to 5 minutes and you hose it off with water. You can scrub it with a synthetic pad, but I'm not sure how much that helps. It may take a couple applications, but you can see the dramatic difference and cleaning power this stuff has.
This dirty area below was above my just recarpted fender guards and I was using it sparingly not to damage them.
It is hard to believe how dirty the boat was.
I found this at my local Walmart for less than $20 for 64 ounces. I probably used 20 ounces to clean the entire Pro175.
https://www.starbrite.com/item/ultimate-aluminum-cleaner-restorer?category_id=565
