Tool useage
Northwest KY. Fairweather angler
This is a re-education post for those of us who have been injured or might be injured by tools, lol #-o :lol:
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh, ****!"
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
Son of a b*tch TOOL:
Any handy tool that you grab and throw across the garage while yelling "Son of a b---h" at the top of your lungs. It is also, most often, the next tool that you will need.
Wire wheel - is very good at grabbing onto your shirt and....
Engine Hoist - I was pulling a 318 out of a dodge van a number of years ago. I wasn't going to be working on the engine anytime soon so I was going to drop it onto one of those hardwood furniture moving dollies. I was lowering it down and because of how I had to pull it out of the van I wasn't able to lift it straight up so it was lowering all off kilter and goofy. I grabbed onto the flywheel to pull the back of the motor up so that it would line up on the dolly. I slipped, dolly went racing down the driveway and the flywheel teeth buried straight through my finger and into the pavement. Yeah, it mostly sucked!! Even worse was I couldn't reach the hydraulic jack to jack it back up because of how my hand was stuck.
Waterwings said:
OXYACETYLENE TORCH:
And what is the first thing you do after putting out the fire? Point the torch right back at the part you just extinguished.
KMixson said:
Waterwings said:
OXYACETYLENE TORCH:
Ain't that the truth, lol
I swear I broke a rib while using the drill press in wood shop back in the 7th grade. Stupid lamp.... :lol:
man that's funny :lol:
my wife always makes sure the insurance is current before allowing the use of power tools, which incidentally usually results in some form of blood/flesh loss. Case in point, recently using the good ol' 3M stripping wheel to strip boat, found the wheel is also really good at removing any wanted flesh on knuckles.
