Transom
allen m
What would you use to seal the rear transom.Would like to recoat the whole thing? #-o
First.... :WELCOME:to the board...
If money allows, the best is to fiberglass it. If that's to much for the budget then a few coats of spar urathane will fix ya up...
Posting photos of your boat, project, or area in question will always get you the most responses... :wink:
Also, if you use the search in the upper right hand corner you'll find a lot of good info on how to do what your doing as well as photos of it....
allen m said:
Thanks, I guess i should of said it is aluminum.
humpfffff...... I can't see why you couldn't paint it to match the rest of the boat then.... I might be missing the point of "sealing it" then... Is it currently leaking at the transom?
PICTURES, PICTURES........PICTURES :mrgreen:
