Trolling motor power wire
mangelcc
Kinston NC
Was wondering where I could find battery power and ground wire approx 12 ft of each, for my motor guide 46 thrust foot controlled trolling motor?
If you're going to leave your boat out in the weather without any cover, I would suggest using tinned wire... https://shop.genuinedealz.com/Marine%20Grade%20Wire/Marine%20Battery%20Cable/4%20AWG%20Battery%20Cable%20UL/ is where I buy all of my wiring from, and I also use 4ga (especially if you want to do a long run of 12').
You can use jumper cables, and people do it - but if I'm using a $500 trolling motor, I don't want to use $20 jumper cables to carry the power. So if you need 24' total of wire (works out to about $50), why not spend a little more and get what you really need that will last you a lot longer and use the type of cable that's made for it?
If you are running 12 feet of wire you are foing to want 8 or 6 gauge marine grade wire, which can be hard to find. I got mine at Cabelas - https://www.cabelas.com/product/Boating/AutoBoat-Batteries-Chargers/Auto-Boat-Battery-Accessories%7C/pc/104794380/c/104698080/sc/104205780/Marine-Grade-Wire-6-Gauge/700341.uts?destination=%2Fcatalog%2Fbrowse%2Fboating-auto-boat-batteries-chargers-auto-boat-battery-accessories%2F_%2FN-1102373%2FNs-CATEGORY_SEQ_104205780%3FWTz_l%3DSBC%253BMMcat104794380%253Bcat104698080&WTz_l=SBC%3BMMcat104794380%3Bcat104698080%3Bcat104205780
I got mine here.
https://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=380208847474&viewitem=&sspagename=ADME%3AL%3ACOSI%3AMOTORS%3A1123
crazymanme2 said:
I got mine here.
I used to use that stuff in my car when I was making myself deaf... it's some good stuff. I forgot about it being tinned too
try your local car audio shop. they will have lots of different awg sizes in any lenght you could desire.
basstender10.6 said:
I would check home depot for some 6 or 8 gauge wire
I used that for running wire to my big foot switch for the rear trolling motor.... I WILL NOT use that crap again in a boat - it's definitely not made for it.
You want a wire that will bend in an almost 180* angle without actually bending in place... Do it right the first time and it will be cheaper in the long run - just make sure you get tinned wire (learn from my past mistakes of trying to "get by" with what should work and will for a little while)
