Trolling motor recess tray on a 1995 175 bass tracker
I have an 04 PT175 and I could not install one of the recess trays as there is a major support cross member where it would be comfy for me. You might be able to remove the front flooring as it's probably wood by removing the screws along each side. I'm not familar with a 95 floor plan, if you could post a pic, or look/feel along the edge of the carpet on the sides and across the front/bow, you should find some screws, and could probably remove them, and then lift up the floor to see if you have room. It's not hard on my 04, just time consuming.
