What's the concenus around here on livewell construction ?
JCR
Wilton,Iowa
you guys that have added them to your boats. You weld aluminum panels in or molded plastic or spray foam ? Just trying to get an Idea of different construction techniques that have worked. I've seen a couple where they turned a seat compartment in to one and that won't work for what I have in mind.. Words are great ...but pictures are way better.. we will get to the pump part later Thanks Jerry
If it was me, And couldn't get alum welded, I would bend some flats and overlap the corners 3/4" rivet it all from the inside, and use some Silicone II clear caulk, that stuff is indestructible...
