Anchor Pulley
kkrueger
McDonough, GA
I got a pulley from a sailboat place then ran my anchor line right through the bow of the boat. Works slick and I can run the anchor line from my seat in the stearn.
At the end of the day I swing the anchor back into the boat for the trailer ride home.
Harken is the company making the pulley if anyone else is looking for one.
On a different boat I had an anchor pulley that mounted on top of the bow, but if you tipped the boat over it would get packed with mud.
is this it?
https://www.harkenstore.com/uniface.urd/scpdinw1.ShowProd?B4RPMEB9Y98HFK
I would think that it would... but I think you could remedy that by cutting the hole a little larger and forming a piece of PVC tube in it, or even better - find a grommet to fit the hole
I agree, find a grommet for the hole so it doesnt mess your rope up!
That looks like a neat accessory for the electric only boats but that anchor would bang the heck out of your hull if you were running an outboard. :shock:
Russ, That looks like the one.
I imagine it does put some wear on the anchor line. But, you're right just drill a bigger hole, or find a gromet.
Also, I would probably flip it in the boat before running at any kind of speed, but for my little electric only it's not an issue until back on the trailer.
