It is currently 16 Oct 2018, 08:56
 Page 1 of 1 [ 3 posts ]
PostPosted: 11 Jun 2011, 17:28
Recently I purchased a 16 foot Jon boat for $900. I needed to upgrade because the 14 foot jon boat I was using was too small for me.
The interior had a non-slip coating applied to it but I'd be tripping over the stringers so I chose to add a floor.
File comment: Interior before shot
I bought treated 2x4's and 3/8 inch plywood. I cut the 2x4's in 4 foot lengths then cut the plywood in 3 inch x 4 foot strips, sprayed them with Johnson Water Seal and screwed them on top of the 2x4's. When a level was placed across the stringers and the wood, they were even. I chose to use white plastic lattice as it won't rot, doesn't get hot, it is lightweight and its durable. I lined everything up and screwed them in place on the wood stringers.
File comment: The after shot of the flooring
I added a 15 hp outboard and a 55lb thrust trolling motor to get around with. I belong to a Jon Boat Club that only allows up to a 16 foot boat and 15 hp motors or just use the trolling motor as many members do. I may power up to a 25 to 30 hp as I fish two other clubs.
File comment: The after shot of the completed boat
I mounted my depth finder transponder to make it portable and not to drill more holes in my transom.
File comment: Portable Transom mount
I use LED magnetic trailer lights as I've learned those 'waterproof" lights aren't always waterproof.
File comment: LED magnetic trailer lights
WE try and keep our Bass alive till weigh in and warm water and Florida heat will cook any fish in a short time. I converted a 30 gallon Igloo cooler into my live well with a aerator. Drop in some ice and keep the water cool and the fish alive.
File comment: Igloo cooler live well
Lastly I have a balance disability so I'm trying to devise a way to mount two "Walkers" in the boat. One on the bow and the other near the stern when i'm steering the boat. Any suggestions will be appreciated.
File comment: Bow Walker mount
File comment: Amidships Walker mount
. That little round thing is an old dehumidifier that acts as a seat until I figure out the mounting.
PostPosted: 11 Jun 2011, 18:46
Normally you don't want pressure wood on an aluminum boat it causes pitting in the aluminum. Since you have a non-slip coating it might not be an issue just keep an eye on it. Don't you worry about things dropping thru the lattice?
PostPosted: 11 Jun 2011, 21:10
For your balance disability maybe a single rail running through the middle of the boat.
You could use seat mounts(bases),mounted in the middle of your seats and attach some type of uprights with cross members.
Welcome to the site.
Users browsing this forum: Bing [Bot], FishinLite, Nic and 56 guests
SwampRunner
