I'm in the process of modifying the trailer that carries my 14' Lund tinnie. The trailer is structurally sound, but was not original with the boat. The trailer is (or actually was), too short for this boat. I don't know who paired the trailer with the boat; that was done at least two owners back. The trailer, while having a Spartan brand name, is titled as homemade. Like the boat pairing, the homemade designation goes back at least two owners.
Here's a pic of the original setup.
![boat & truck.jpg boat & truck.jpg](https://cdn.imagearchive.com/tinboats/data/attachments/99/99997-a90dd8f77cc13ac13bc6b8915953796f.jpg)
I'm modifying the trailer because there are several issues that the original configuration presents.
First issue: The trailer axle is nearly under the center bench of the boat. It has almost no tongue weight; I estimate tongue weight to be about 30 pounds at the most. This leaves a very minor bit of a side-to-side wobble when towing at speed.
Second issue: The winch post is too close to the tow vehicle. The only way I can let the tailgate down on the truck with the trailer on the hitch is to have the whole setup absolutely straight. Even that situation only allows about an inch of clearance between the top of the tailgate and the winch post.
Third issue: I have to back the truck too far down the ramp to launch and recover the boat. I'd like a little more room so that I don't have to get wet feet every time I recover the boat.
Fourth issue: I have to use a jerry-rigged ratchet strap setup to strap the boat for trailering. I'd like the straps to clear the bottom edge of the transom when they're hooked to the boat.
Fifth issue: There's only about 1/4" of clearance between the transom saver and the bottom edge of the transom when the boat is loaded on the trailer.
Sixth issue: The bunks are a mess, and I've let that situation go on far too long. I'm going to reconfigure the bunks to provide better support.
I've now welded an extension onto the tongue; the trailer is now 45" longer than original. Here's what that looks like:
![Extension weld.jpg Extension weld.jpg](https://cdn.imagearchive.com/tinboats/data/attachments/99/99998-715a0b0520dde337521358fe9b1a63b5.jpg)
I put the boat back on the trailer and I'm now working to get the rest of the configuration right. The keel is resting on two of the three center rollers. The only roller it doesn't contact when loaded is the roller at the aft end. The forward-most roller is about under the boat's center bench. I think I need to add one more roller forward of that point to preclude the boat's keel contacting the trailer tongue when recovering and loading onto the trailer. Any thoughts anybody has on that aspect are welcome. Here's a picture of those rollers:
![Keel rollers.jpg Keel rollers.jpg](https://cdn.imagearchive.com/tinboats/data/attachments/99/99999-6bd94ecb85c327ee3646540f875ce341.jpg)
The winch post raises my next question: Should the bow eye be underneath the rubber boat stop on that post or above it? The bow eye has been above that rubber stop ever since I've had the boat. This is my first boat, so I have no experience to lean on. The whole thing is easily reconfigured. Pic:
![Winch post & bow eye.jpg Winch post & bow eye.jpg](https://cdn.imagearchive.com/tinboats/data/attachments/100/100000-264d2477bad19bb82f88f16210420b86.jpg)
My last question concerns the position of the transom over the back end of the trailer. Should the bottom corner of the transom be aligned with the aft end of the trailer? I'm thinking so, and the bunks should likely protrude beyond the transom by an inch or two. I still have the ability to move the boat forward or rearward on the trailer very easily. As you can see in one of the pics above, I'm using a chain hoist to an overhead I-beam in the shop. Shifting the position of the boat fore or aft only takes a couple of minutes and can be done by me working alone. Here's a pic of how the transom position on the trailer right now. As you can see, the bunks are a mess and I'll fix those just as soon as I'm settled on the exact position of the boat on the trailer.
Other items yet to be done are tail light brackets, rewiring, repainting, and possibly the addition of "bump boards" to the sides of the trailer so that solo recovery is easier in windy conditions.
It has been a blessing to have a fishing buddy who has a good welder, and that he knows how to use it.
Thanks for any thoughts you have on the questions I posed in this lengthy post.
![transom over trailer end.jpg transom over trailer end.jpg](https://cdn.imagearchive.com/tinboats/data/attachments/100/100001-e16c033fe8de8d78013e4b80035799b9.jpg)
