Boat weight "Tracker"
moevus
Gainesville, Florida
Found that 1990 Deep V-17 weight is 675 rated @40hp, 1991 & 1992 is 871 rated @60hp but 1993 is 1586 rated @ 40hp.
Recently saw a 1993 Deep V-17 in person and plate said rated @90hp max and has 60hp Johnson on it.
Info from J.D. Power prices, values, specs.
What gives? Must be incorrect information?
Anyone know that weight of a 1993 Deep V-17? Boat has everything, storage port & starboard, live well, front storage.
On iBoats I found it, 1993 V-17 Tracker 871lbs, 77" beam and 3 motor options from Tracker 40,60 or 90hp. 90 is max.
What a great site.
I have an 84 Tournament V17 that is rated for 90hp maximum.
Perhaps they have the ratings mixed up between the Deep-V and Mod-V models, the model names changed quite a bit throughout the years. The 17' Deep-Vs are all rated for 90hp throughout the years as far as I'm aware.
I'd say their weight is about right at 800lbs, I have never had mine across a scale.
I agree with iBoats, must be around 800lbs.
I guess a 60hp should do fine. Has a Dol-Fin too. I always liked the 3 cylinder Johnsons.
I had a Triton 2000 17' aluminum with a Merc 60 and did fine.
I've had several different motors on mine, the original 60hp Merc, a Suzuki 75hp 2 stroke, a 90hp Fourstroke, and now a 50hp Evinrude. The Evinrude is probably my favorite in terms of power to weight, the 75hp+ motors get very heavy. 50-60hp is perfect IMO.
