1448 Tracker Grizzly Project Thread
HenryTinSkiff
Going to be starting a 1448 Tracker Grizzly to flats skiff project in a little bit. Here are my plans. Trolling motor in the front, tiller console with GPS and switch panel, and poling platform. I wanted to start this thread now even though I won't be fully starting for a bit because I have some questions that maybe you tin boat experts could answer.
My tiller console will be in the middle of the cockpit. I want to run a one battery system. I need to wire up to the trolling motor and nav lights and back to the bilge and nav light. I will most likely put the battery under the tiller console. My question is how will I get the wires to the front and back of the hull? I am new to this. I have seen somewhere that there is a channel in the bilge for wiring but I'm not sure.
Thanks,
Henry
Dunno if this will help but here is a video on YouTube with same boat and wiring a electric anchor i think to the bow
https://youtu.be/s9oVNt0f46w
Well it helps answer part of my question which is that there is a channel in the center of the boat for wires. I still don't understand how I could wire the boat from the center of the cockpit. Anybody know? Maybe I could drill all the way down into that channel?
