15 hp johnson outboard motor seahorse
Northern Maine
Does any one know where the serial number is located on a 15 hp johnson outboard motor seahorse. I believe it is a 1983 but I am not really sure. I would like to find a service manual for this motor. Any help would be greatly appreciated. Thanks!
Should be on the transom clamp.If not there is a quarter size freeze plug on your motor block that has the numbers stamped on it also.
Serial number is not needed for parts or year of that motor, You need the model number.
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
The numbers correspond to the letter above them in determining the age of Johnson Evinrude motors of the 80 and above.
If your engine is an 83, you'll see the letters, CT towards the end of your model number.
