1966 Johnson 20hp - grayish colored oil in foot
J.C.
Robertsdale, Alabama
Hello everyone, I am in the process of getting my 1966 20hp Johnson into proper working order. I bought it used and have rebuilt the carb and rebuilding the shift handle where it was broken. The last time I had it out I replaced the oil in the foot and noticed that it was grayish in color, I went ahead and replaced the oil and took it out (already promised the kids) When I got home i drained it again and of course there was the grayish oil. I am new at this and I have seen people talk about this being a problem, so this leads to my question. What do i need to replace to keep the water out of my oil, and is it very difficult?
Thanks to everyone!
Thanks to everyone!
When you changed your gear oil, did you change the drain/fill plug washers too? If that doesn't work, I would buy a gearcase seal kit. Most of the job is easy to do. Changing the shift rod seal can be a challenge, but someone can help you make a tool when you get to that point. Good luck.
