Well, lost last post so will try it again.
Rear seat area: Modified and removed about 12" from front of whole bench. Where gas tanks sit now there was foam with bench screwed to supports with aluminum panel goin across the front. Battery sits in close to original location in new box. Whole bench is removable and slides forward to access battery and lifejacket storage. All foam was replaced and moved to other areas. Under floor is all new foam and a lot more dense than was in there. Sturdies it up alot also. New 1/2" floor.
