Hi all. Have a 2006 merc 15hp 4stroke. Got stuck on the water.
Symptoms: keeps shutting down after 10-15 seconds when bring throttle down to idle. When you start it, it starts at a really high rpm. Sounds like i sam starting it with half throttle open then when i go to lower the throttle it cuts out.
Checked and purchased a new gas line and bulb, Opened the carb and it looks brand new inside. Check the fuel pump and also looks new. Took off and cleaned the gas filter.
Issue found: Coil is showing low yellow spark
Changed out the coil still no fix. Can it be anything else other then the CDI? because if not i will order 1 now.
Thanks in advance for your help!
