thefirstbert
Hey guys
this is my first post and I hope you guys get as excited about this as I am.
I am slowly refitting a 21' aluminum tracker party deck (not pontoon) to a fishing boat better set up for these shallow Illinois waters. It currently has the deck and everything except for the engine removed.
The boat came with super heavy 5/8ths ply wood that was probably 50% water. It also had a fair bit of floatation installed that held plenty of water also. I have removed the flotation and decking. I am going to reinstall the pour in foam but I will be installing water channels under the foam to help the water flow towards the bilge pump instead of sitting and getting soaked up by the new foam.
I am then replacng the plywood with the lightest gauge aluminum flooring I can but I have no idea what thickness I can get away with.
The stringers are 16" apart and I will be adding 1 in the middle and 1 on each far side(front to back) and I will be adding cross bracing (left to right) every foot. I have read about everything I can find about this and believe that I pretty much have It down to 0.063 or 0.08 thick 5052-H32 sheets.
I dunno???
I am thinking Ill drill holes in the sheet and tack welding (spool gun) every 6 inches along the stringers and crossways along the ribs.
The problem with this method is I cant install it over eps foam. I like the foam idea because I bet it would quiet down the wave smacking but my brain says tack weld for strength...
So,
can 0.063 span across my 16" x 12" openings?
should I tack weld or install over 1" eps pink foam with screws?
thank you
PS the super heavy 4.3 mercruiser will be replaced with twin yamaha 701 2 strokes and jet drives in the future. that will save me about 500 pounds and give me about 150 HP total in a boat that should total about 1200lbs
![deck bracing.jpg deck bracing.jpg](https://cdn.imagearchive.com/tinboats/data/attachments/93/93031-c17f205c79b2b632ba4646a3bda483a9.jpg)
So,
thank you
