Roost said:
No worries Kevin, Don't hold back. I appreciate your thoughts. I'm curious what your concerns are and I'm really anxious to see the pics of the motor in one of your boats.
Generalities here…
The pump is the limiting factor. Since the 250/240/200 share the same intake/housing/impeller/stator/nozzle etc… Impeller speed is the only variable. Unlike a prop, low end torque isn't important to the SJ. Thus the 250’s low end torque would be of little use for your proposed build. Actually, it’s a liability. With a shallow deadrise and raised tunneled intake, the impeller sits high in the water. The impeller can’t absorb near instant torque, thus “blows out”.
On the other end of the spectrum, the under driven SJ impeller’s perf drops off substantially above 4000 RPMs. If I remember correctly (shooting from the hip here) the 250 Power Head maxed out @ 5600 RPMs, thus the 1.15:1 under driven impeller was turning @ 4900 RPMs. But there was little difference in top speed from a blade speed of 4500-4900, so essentially you’re just burning more fuel. Also, unless it’s a finely tuned hull / tunnel design, pump loading above 45-48 MPH will be a struggle.
