I take it this is a saltwater engine? The more information you give us the better the answer we can give you........... Anyway, since there is no picture you posted, if this model has the shifter on the side of the engine there is a cross shaft that goes toward the center of the exhaust housing that has two bushings. Chances are these bushings are dry and have corrosion in them and are binding the shaft. Not the easiest of repairs as far as time goes but fairly easy if you are mechanically inclined. Since you seperated the gearcase from the midsection another thing you did not mention in your last post was whether or not the gearcase shifted easily or whether the shifter handle was still the hard part to shift. Again, more information the better. We cannot read minds nor are we there to look at it with you.
