New project and just got the shop manual. The first maintenance procedure is to adjust sync & link. First operation is setting cam follower pickup point. Not only was my follower not touch the the cam, the hash marks are behind the follower by about 1". Looks like the cable has to be tightened to advance the follower to line up between the 2-hash marks. It appears the cable does not rotate within the throttle cable bracket, the bracket must rotate on the cable, and the only way to do that is remove the entire bracket and rotate it on the cable, install the bracket, and recheck to be sure my follower is between the hash marks. Seems a bit backward, am I missing something? Thanks guys...
