fowlmood77
Front deck supported with angle aluminum
Switch panel, 12 volt plug in w/ fuse box mounted under rear brace
Livewell overflow with plug made from PVC and siliconed into existing drain. You can see the factory setup that was the black tube that fit into a holder on the side to hold water in.
More to come
More to come
