Babills,
Forget the terminology and semantics, they are irrelevant. The issue is your safety and the longevity of your valuable electronics.
Make sure you have a fuse (or circuit breaker) inline with each device. Without knowing the exact details of the electrical layout of your rig you might also want to protect the wires that run from the battery to whatever the connections are where you plan on adding the GPS and fishfinder. The size of the circuit breaker or fuse should be based on the size of the wire. The idea being if the wire(s) rub through the insulation and come in contact with some they shouldn't the protection device sacrifices itself and doesn't fry something important.
As far as noise and interference from other onboard gear, try it and go from there. If you have a problem, it can be resolved without too much of an ordeal.
I don't live in Michigan anymore, but it will always be home.
