BaitCaster said:
I found an 18 hp Johnson on CL. Guy says it starts easy, runs well, idles well, trolls well and has good compression. He will run it for me. Only problem is it is a 1960 model! I am concerned that: a) even though it runs good now, if I have problems parts will be next to impossible to get for it, and b) the thing must weigh a ton.
He wants $400, which seems high to me. Any advice?
BC
Hey BaitCaster,
I've read a bunch of articles by older mechanics and fisherman regarding the 18hp motors from 1956 to 1973. All who own them, love them. They are great motors if kept up well and easy to work on. The 18hp, 20hp and 25hp motors in that era have alot of interchangable parts. Parts can still be gotten.
Parts:
https://www.marineengine.com/parts/vintage-evinrude-johnson/378126/catalog.html?https://www.marineengine.com/parts/vintage-evinrude-johnson/378126/37812600001.htm
https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1960&hp=18
Hard to find parts or NLA(no longer available) can easily be gotten on ebay or better yet AOMCI (Antique Outboard Motor Club, Inc).
https://www.aomci.org/cgi-bin/yabb2/YaBB.pl?board=Webvertize
Just join the site(its free just like this one), but you a freely adverse for parts you want on there webervise section. I've gotten parts for my 1970 18hp Evinrude that I am currently restoring.
Check to see if the motor is using a fuel pump with a single line system or using the 2 fuel line system with a pressured tank.
Pressurized tanks are harder to get, but can be gotten on ebay, craiglist, and naturally AOMCI (Antique Outboard Motor Club, Inc).
If the motor is still using a pressured tank and 2 hose fuel system, you can convert to a fuel pump and single line system at an added expense.
Here is a write up.
https://forums.iboats.com/showthread.php?t=205628 (you will have to join the site, just like this one to see the pictures in the diagram, and it is free just like this one.
https://forums.iboats.com/showthread.php?t=380378
https://www.sschapterpsa.com/ramblings/Converting_dual_fuel_line.htm
I am not a 100% certain, but I think motors before 1963 used 24:1 gas to oil ratio (6 gallons of gas to 32oz (1quarts) of TCW-3 2cycle oil).
I think motors in 1963 and after used 50:1 gas oil ratio (6 gallons of gas to 16oz (1pint) of TCW-3 2cycle oil.)
If the motor is in excellent running and cosmetic condition and make sure it is pumping water out of the exhaust relief part on the back the midsection. Then about $300 to $350 is an good asking price. That is the price in my neck of the woods, your area may have a higher value.
If you buy the motor, please get a service manual for it, so you can properly maintain and service it. You would be hard pressed to find a mechanic willing to work on it. Most prefer the new outboards, because that it what they were trained on.
PM sent
Good luck my friend,
cajuncook1
