bilge pump
malaki
edgar co. Il.
Picked up a cheap pump at walmart in case of rain on an upcoming camping trip. Not a big fan of drilling holes below the waterline. Thought about mounting it to the center transome support but the livewell pump is on one side and the battery on the other and a rivet prevent it from being on the bottom of the hull, mainly the rivet. would it be a good idea to wire a plugin so i can drop the pump in when i need it, and be able move it to empty the livewell after use or will it just float? normaly its only on the water a few hours at a time and back on the trailer just got the pump for times like tis where it wont.
I've been going through the same decision, where to put the pump, but have think I have found a spot. That said, I like your idea of making it "portable" and using it as needed. I would try that, but my luck, would lose it!
