Thanks for the responses guys. Here is a pic of it right now. That side console is two pieces, top is fiberglass, bottom is carpeted aluminum. And you can see the bench seat arrangement. Thos seats and console are very low. I boat every day I can, whihc is a lot, and it is very uncomfortable for a big guy like me to get up out of the seat all the time because you are practically on the floor, I am 6'1. Plus when I am alone, which is 90 percent of the time, I'm sitting on the right and the boat leans and I can't stand that.
I would like to retain at least the top half of the original console, and build a new base for it so it is sitting higher and move it towards center and back about a foot or so. Remove the bench seat setup and just mount the seats on the rear deck with the console in the center and build a partition and storage area on the drivers side of the console to fill in the space, hide the wiring and steering cable, and make it look flowing instead of half-a$$ed. I only need to be able to walk around the pass side of the console to get around it to the front area. The drivers side I would like to close off and make it wrap around the center cockpit. Also will need to move the throttle controls inboard.
Hard for me to explain, I will try and get some pics up to describe what I mean. So if I can accomplish that, I will mount seats and storage in front of the console and open some of that front deck up for walking room. I am using this boat mainly for catfishing, so I want to get rid of the bass fishing layout and modify it more to my likings since I spend more time on the boat than I do at home. Also as you can see, the boat is in great shape so I don't want to destroy it in the proccess.
