I finally got around to starting some work on my 14' myers super pro and figured while it was off the trailer I'd pack the wheel bearings. One side was fine but the other side was wiped out. I figure, no problem, I'll go grab a new set and pop em in and be set to go....WRONG!!
I ended up having to order bearings from a specialty bearing shop here at a cost of $57 per wheel and as of yet still have not been able to find a seal that will work. It's an oddball metric size and nobody has anything to fit.
My last ditch effort before replacing the trailer or the axle is to try oversize seals (1.5mm) larger O.D and trying to sand out the hub area where the seal fits. Wish me luck.
