Lil' Blue Rude
What normally happens... the motor blows up. The reed will get sucked into the cylinder and if it's lucky it won't get snagged in between the port and the piston on it's way back up. Pretty much the piston ends up chewing on the reed until it get spit out the exhaust.
If the reeds is stuck any where it will be in one of the intake port runners. It's your motor and do as you please but the only way your going to know if the reeds out and didn't hurt anything is to split the crank case and pull out the top pistons. That's my 2 cents.
