My old grumman boat had marine plywood.
It was heavy.
I didn't realize how heavy it was when I first bought it. It was good enough for me. Little while later, I wanted to strip the faded green paint off of it and then camoflage it, inside and out. I removed the plywood and insulation under it, painted it and then during the painting process a guy I worked with at the time had some leftover .100" thick diamond tread. I got it from him for under $20 for 2 4x8 sheets, only used one and a half. That boat with the aluminum floor was probably 40-50 lbs lighter than the plywood was, and it will never rot. I just riveted it onto the ribs, on top of the closed cell foam insulation.
For a pattern, I used stiff cardboard. A flat bottom is easier than a semi-vee because the center doesn't have to be bent. Just cut the cardboard to fit exactly like I wanted it to, then cut the aluminum. Big cuts with a skil saw (wear ear protection AND eye protection...). Smaller cuts with either a hack saw blade, a hack saw, sawzall, or a body saw. The body saw saw more action than anything else, and I still use it for other projects. They are awesome. It's like a mini sawzall that reciprocates the blade about 10x faster than a sawzall.
I bent the outer edges downward, which helped stiffen up the floor. That was the only bends I had to make. Initially I didn't bend them down, but the first time I stood on the floor, I noticed flex around the edges, and because I have seen War Eagle's floors (which are all bent downward at about a 45° angle), I decided to try that, thinking at least all the junk that lays on the floors would stay around the edge. The bend stiffened up the entire floor as a whole. I just did it on the edge of some 2x4's with a soft face hammer, a little at a time. I put one 2x4 underneath and another one on top and clamped them with the floor in the middle and hammered it out. Worked good, just took forever it seemed. Thats where a brake would come in handy, would make the bend a LOT faster.
Friend of mine did his Waco 1448 same way but left it a polished finish as opposed to painted like mine is, and his is only .075" thickness (IIRC). Lot thinner than mine is, but it works fine. It flexes a little more though.
