You are absolutely correct, dissimilar metals especially in combination with aluminum will cause rapid oxidation of the aluminum as it gives up its electrons. Copper, especially alakline copper quat is particularly bad, common in PT wood. Pressure treated wood of any kind will always contain a metal that reacts with fungi and insects to 'short circuit' if you will their chemical makeup, thus making it bug/rot proof.
The bluewood treatment uses no metals, and is quite inert. It mimics what nature does with cedar and its natural mould/bug/water resistance. Its not pressuretraeted, and you can buy the stain as you would any paint. Its just easier to buy it pre-stained, but you can use it on any wood. BUT its not designed for constant submersion in water or wet soil (ie fence posts in the ground).
Bottom line is dont use the PT when its in contact with metal that hasnt been treated to resist the ACQ in the wood. Thats why they make deck screws specific for PT wood. Aluminum boats arent ACQ proof!
