the more you use it,the more you will try different meathods. its not a really steep learning curve.you dont have to spend a lot of money.a reel only holds your line, and not used for anything else,so a cheapo with a fairly good disc drag is all you need.you can stay away from high end rods unless you plan to do a LOT of long distance casting. i trol l90%of the time with mine.a good sink tip line and a bunch of tapered leaders is all you need to start.
