How to convert tiller steer to a console
Update on console
Here is my throttle control mount I made
Just finished shifter mount for the controls.
Why did it repeat my photos??
Have you hooked the controls up to your motor yet? I'm looking to do the same thing with my 92 Evinrude 30 hp electric start.
Sent from my VS990 using Tapatalk
evansjoem said:
No haven't yet
How easy will it be do you think? I'm wanting to do the same thing your doing. Will I be able to do it like yours?
You should be able to buy a kit for yours. I am going to fabricate all of my pieces
Well I'm a welder/fabricator myself so I'm Def going to watch to see how you rig it up!
Do you have any ideas yet for how to rig up the shift lever to the console?
I have two bolt holes on the front and will make a plate with a tube welded to it. Then I can buy the arm for it that will go through the bottom and bolt in and then bolt to the steering cable. Mount the steering cable to the transom
Here is the mock up for the steering
