[url=https://www.tinboats.net/forum/viewtopic.php?p=334871#p334871 said:JMichael » Today, 22:03[/url]"]Buy a new end, cut all four wires at different lengths so that all of the splices will be staggered/off set from each other. Cut the trailer wires length to match up to the lengths of the new end. Slide a piece of heat shrink over each wire before you solder them together. After you have soldered them all together, slide your heat shrink in place and shrink it. Then wrap the group of wires with some tape. Preferably somthing like 3M's Self-Fusing Silicone Rubber Electrical Tape.
how do you connect to the lights with no connections to corrode and cause shorts?TNtroller said:Just be the devils advocate, it's not hard to re-wire the entire trailer, just buy a kit for $20, and no splices to corrode and cause shorts, etc. My $.02
[url=https://www.tinboats.net/forum/viewtopic.php?p=338616#p338616 said:Bugpac » Tue Jan 14, 2014 1:51 am[/url]"]how do you connect to the lights with no connections to corrode and cause shorts?TNtroller said:Just be the devils advocate, it's not hard to re-wire the entire trailer, just buy a kit for $20, and no splices to corrode and cause shorts, etc. My $.02
I think I may have run in to some of your dad's work before. What state did he live in. :lol:[url=https://www.tinboats.net/forum/viewtopic.php?p=338656#p338656 said:earl60446 » Today, 13:39[/url]"]
My dad would of twisted the wires together and made sure they stayed apart sorta kindof. Then after blowing about 10 fuses wrapped it with some duct tape or something. :roll:
Tim
I was being sarcastic.!! If you cant have a splice you cant connect the lights!!TNtroller said:[url=https://www.tinboats.net/forum/viewtopic.php?p=338616#p338616 said:Bugpac » Tue Jan 14, 2014 1:51 am[/url]"]how do you connect to the lights with no connections to corrode and cause shorts?TNtroller said:Just be the devils advocate, it's not hard to re-wire the entire trailer, just buy a kit for $20, and no splices to corrode and cause shorts, etc. My $.02
Di-electric grease works wonders, a little bit off preventive maint goes a long way.
