hull slap
snooker
Anybody have any ideas or tried something to prevent or dampen hull slap noise. I have a 1432 flat.
Your motor maybe too far away from the transom, there are several notches for the bar, bring the motor close to the transom, just might help, jus saying.
I would think....
Foam
Framing in the bow
Bedliner Coating
would all help with it.
Brine said:
I would think....
Foam
Framing in the bow
Bedliner Coating
This ^.
If you are talking about hull slap from waves spooking fish while you are fishing, some guys around here will hang an old piece of carpet over the bow.
How about after market fin stabilizers added to the motor for a better hole shot and over-all ride with less porpoising?
Nah. Just hang it over the bow and sit something on it so that it doesn't fall off into the water.
That way you can do whatever you want with it when you don't need it.
Just a thought...
put one of your buddies in the front and run the boat, if you have no more slapping move your battery or gas tank up front.
