vahunter
This isn't a Tinboat so I didn't want to post in the boathouse or anything. But some of you duck hunters may have seen (or built) one of these Hybrid NL layout/marsh boats. I built it with plans/instructions. The 'plans' are more like instructions so everything can be customized and built the way you want so its not really a template build. I used plywood and glassed it with epoxy resin and painted an open-water type of camo pattern I think will work well. It should weigh around 65# but I haven't weighed it yet. It's a stitch and glue build using resin and fumed silica as glue and fillets. It's powered by paddle or towed/toted to location by tender boat. I added a motorboard for a trolling motor incase I ever decide to register it (VA law). For the bottom I did a graphite powder/resin for a scratch resistant surface also adding runners.
