~DJ~
I have a mid 90's 12' aluminum Gregor boat I recently bought used. I noticed that where the transom meets the floor there is a lot of what appears to be silicone sealant. Anyway this is where the leak started. I have removed the silicone and underneath that is a rock hard white substance that is difficult to remove. I have removed some of it and noticed I can see a sliver of daylight through the seam where it was leaking.
My question. I have a can of Gluvit coming. Had good luck with it in the past. After getting it cleaned up and wire brushed I was going to tip the boat up and pour it into the seam about an inch thick. Do you think that will work or do I need to find someone to weld a bead across the seam? Thanks so much.
