Bubba
Is it really tricky to adjust the idle of an outboard? I'm pretty sure the idle on mine(90 yamaha 2-stroke) needs to be raised just a hair. When i'm idling in a wake zone, if I just push it just enough to get it to go into gear(idle), the motor kicks and kinda vibrates(not horrible, but it doesnt run smooth) like it almost wants to die...you can feel it shake the boat. Then I can push on it just to give it a tad more throttle and it'll smooth out. I've looked at the rpm's, but I swear I can't remember what they were. It runs fine when running anything other than just idle, so i'm pretty sure there isn't anything wrong, I just think the idle may need to be adjusted up a couple hundred rpm.
What speed(rpm) does your guys motors idle at? And is it hard to bump up the idle speed just a tad?
