Ranchero50
Got the call, jet foot cracked, found a tall rock in deep water at idle on the Susky. Didn't look bad until I took the mangled grill bars out and tapped the cracked edge with a hammer. Instant two peice foot. Used the die grinder with an aluminum burr and bevelled the cracked edge, welded the cast aluminum back together with the Mig...
Then I took some scrap aluminum and made some intake fins to help reinforce the cast and if they get buggered I can fix them easier than the foot.
Now once the new wear ring, key and sleeve get here I'll get this thing back together. Something sheared the key and the sleeve was washed out pretty good too. The wear ring was junk the other year when we filled it with epoxy and most of that was eaten away this time.
The boat is a '01 Ranger 116 Cherokee, aluminum hull with a 90-65 Merc, an ungawdly heavy beast for shallow running.
Jamie
Jamie
