Levi's 14' Springbok Project
QMR
Hi
Here is a link to my son's 14' Springbok Project.
https://www.charityflight.com/boat/
He is always looking for advice.
Please have a look and chime in on the JBWeld or 5200 question.
Thanks
I would use the 5200 a long time before I would ever use JB Weld... JB Weld is good for some uses, and some here may like it... but in time, as I've seen on a boat at our pond that is more then 20 years old, it disintegrates and just falls off. 5200 is the real deal.
I like the website... good job
5200 is no doubt the ideal sealer for sealing around bolts and other hardware mounted below the waterline, but I question the ability of it to patch a hole on its own, as opposed to it being used to seal whatever you patch the hole with. I have never actually tried patching a hole like that with sealant alone, so if someone else has experience with it, I am all ears, but I would be a little hesitant of using without hearing actual accounts of it's use. It looks to me that the hole is on a chine, right? That is a tough place to form an aluminum patch to rivet on, so I am almost inclined to say that I would get it welded, and those that know me know I am the last person to recommend getting a hole welded as opposed to a rivet on patch. Just my 2 cents worth.
Weld it! Keep the front end pieces you never know you might like to put them back on some day. What size motor are you going to run?
bassboy1 said:
5200 is no doubt... It looks to me that the hole is on a chine, right? ... Just my 2 cents worth.
Hi
The crack, about 3/4" is across the drip channel on the bottom.
I would use this before the 5200...
https://www.outdoorsuperstore.com/product.asp?prod=252704
I've filled holes in other boats of mine with this, and they are still going strong. Just give it a few days to fully cure before you put it in the water -- and keep your fingers off it until atleast the next day after you get it set. I would put it on the inside and outside. You can sand it down after it's cured
I have been trying to figure out how to fix a spot on my boat. once again thanks for the idea russ010 and QMR for the question.
https://www.dalehollowoutdoors.com/aluminox-epoxy-stick.html
Ok well it's been a week since I fixed the crack. The 3M 5200 is the ticket! Solid like a rock. We had a torrent of rain over the weekend and the hull got 3 inches of water in it. No drips from the crack or the keel seam I sealed up.
On to the frame for the decking.
update: The 14' boat is gone. But we got a new one!
Just purchaced a 1967 16' starcraft with a 65HP Merc.
I removed the seats and found some wood decking has rotted out. I have removed the bad wood and am going to replace it and put in new carpet and vinyl. I haven't taken any photos yet.
More to come.
