Need Part numbers
chopper6322
corpus christi TX
Hey, can anyone find part numbers for a carb kit and a fuel pump kit for a 1970 Wards Sea King 6hp (made by chrysler) The carburetor is a tillotson mt91B and i have no idea on the fuel pump but will need gaskets and the diaphragm (not sure what all comes in a fuel pump kit) Thanks in advance
https://www.marineengine.com/parts/sierra_marine/catalog.html?https://www.marineengine.com/parts/sierra_marine/chrysler_force.html
Does your fuel pump gaskets look like that?
Pics would be nice of both carb and fuel pump.
Steve
that is the fuel pump kit, but a different carb kit, it's a rectangular shaped bowl about 3 inches x 1 inch, really all i need for the carb is the gasket for the bowl, i guess i could just get some gasket material an cut my own, does that stuff work the same as a specific gasket?
If you can cut out one that resembles the original closely enough, it will work fine. I found the easiest way to make bowl gaskets is to turn the bowl upside down on the gasket material, draw the outline of the bowl, then place the original gasket within the bowl outline and draw the outline of the gasket. The bowl outline is used to make sure you don't have the original gasket distorted while drawing. Once you get your outline drawn, use an exacto/razor knife and cut the inner portion away first so you can use the outside edges to hold the gasket in place. Now cut the outer line and see how it fits. Trim as needed and you should be set.
