Quackrstackr
I had a couple of buddies in this weekend to fish and we decided to go out on a night trip last night. We ran probably 15 minutes in the dark to where I wanted to fish and I kicked the trolling motor down. I was too far over on the flat (couldn't tell where I was in the pitch black :lol: ) and decided to crank the big motor and idle over to where I needed to be.
I pulled on the locking pin rope for the trolling motor and the pin seemed to be jammed. No big deal, it's happened before. I pulled on it again and just about fell into the floor of the boat. I thought the rope had broken. It wasn't unexpected as it had started to wear a little bit where it ran through the hole in the aluminum bracket. No problem, I'll just feed it back through and tie it off and it will be a little bit shorter. I flip on the light... the rope still has the knot in the end of it. :x The entire mount is made of metal except the slider that the locking pin goes through with the spring attached to it and the pull rope ties to... it is plastic! The eyelet molded into the end of it where the rope ties just snapped right off. :x :x
Of course, this piece is underneath the top bracket...
I also found out last night that there is no manual release for the locking pin on a Motor Guide except for the one that the rope is attached to. You break a rope or that one stupid plastic piece, you're screwed. You can't raise the trolling motor.. period.
Here we are 15 minutes from the boat ramp, in the dark, haven't even started fishing yet and the trolling motor is broken... and stuck in the down position.
Thankfully, at least you can unscrew one large knob and take an entire Motor Guide out of the bow mount bracket. I was so disgusted with the broken motor (and the fact that we had planned to fish today as well, but now had a broken trolling motor) that I just took the thing out of the bracket and threw it in the bottom of the boat so that we could even run the big motor. We called it a night without fishing at all. We made a yoke out of some 250# test dacron bowfishing line to tie the release rope to just so we could go out today.
I have managed to find that part on one site on the internet. One. Looks like I'll be calling them tomorrow and ordering one. I can't believe that a piece that important is the only functional plastic piece on the entire motor mount.
I had people warn me against Motor Guide when I ordered the boat and I tried to save a few dollars. Lesson learned. I've had more problems out of this trolling motor than any motor that I have ever owned... and I have owned several over the years... but this is my first MG. I suspect that it will also be my last.
