Old timers formula questions
Jerryd352
LOCATION
Keystone Heights Florida
I’ve been reading through a bunch of posts on the forums and finally decided on going with the old timers formula for sealing my deck. I had a few questions before I begin that I hadn’t really seen many people touch on.
I’m going to be sealing 19/32 BCX sanded pine and was wondering if I need to sand the plywood further before treating due to it still being slightly rough. Do I need to sand all edges before sealing?
I’ve read a few threads where it mentions if you live in a humid climate to cut one part (I believe it was linseed?) due to mildew/molding of the plywood. I live in Florida where it’s always humid. Has anyone experienced any issues in Florida using the original 1/2/1 OTF?
I plan on pre-drilling/cutting everything prior to adding the OTF. This is my first build and any input would be greatly appreciated.
Jerryd352
LOCATION
Also how far does a full mix of 1/2/1 mix go? I’m decking a Alumacraft 1648MV from front of the boat to the back side of the middle bench, as well as the entire back deck (front of back bench to transom).
LOCATION
Tignall georgia
I don't know who was the originater of otf, but they invented something great. I did a 15 ft jon with it several years ago, and after curing out. Took a piece of the boat where i removed to put in a seat base. To home depot and had floor and deck enamel mixed to match the boat. That was 4 years ago. I redid it this summer and the plywood had small cracks on it. This time it soaked twice as much as before. I feel like this last soaking will last many years. To address your question on coverage, a little will go a long ways.on your first coating. I left my plywood after treating both sides originally to bake in the sun for a week before installing. Our summers here in ga get very hot seems like the plywood will soak up more if left out in the sun to bake.
Btw i put the sealer over the top of the paint and it absorbed about twice as much as originally done. I have done a wheel chair ramp with it twice and it has held up great. Plans are to put another coat of paint over the last boat refinishing, in about a month, with a light dusting of sand for slip resistance.
SAABologist
College Station, Texas
Mos Def, go with the old timer's mix over BC/X.
If I were doing mine again I would use old timer's mix instead of the acetone-thinned epoxy. The epoxy made the plywood bullet-proof, that is not the issue. I don't think my plywood will rot in 25 years.
The reason I would use the old timer's mix is because I would be able to use normal carpet/vinyl glue instead of the cumbersome and very expensive contact cement that you have use over epoxy or fiberglass.
