Power tilt
newellri
I have a new 20 hp Merc without power tilt. My question is can it be added after. I am having to pull up motor in shallow water in my 70's it is difficult. Thanks
Sometimes it is cheaper to sell the Non-tilting motor and buy a Tilted motor.
Or, you could try one of these "Tilt-assist" devices.
https://www.wholesalemarine.com/garelick-curved-outboard-motor-tilter.html?gclid=Cj0KCQjwub7NBRDJARIsAP7wlT9cQalGiqUuxELagIfC9XdEVy_py9ICST2V5I-Oq29bmcadk7Y-T-waAqdsEALw_wcB
I'm also in my 70's and wouldn't want to tilt any outboard these days.
You would need to research your specific motor to see if there was a power tilt option and if so find the correct part #'s. My 60/45 jet was manual tilt which I did for a year and then I found a brand new PTT setup on Ebay for $409 shipped. It retailed for over $1000 I think but if you take your time searching around you might be able to find something affordable. The CMC setup might be your best bet if Mercury doesn't offer it.
Check this out - fairly simple to do using a Lenco trim tab actuator with a 4" travel:
NOTE - it's not strong enough for power trim adjustments while under power, but that's not what you're asking for
https://youtube.com/watch?v=zr5efT3xo30
Great idea on using the Lenco.
I owned a NMZ Gheenoe a few years back. The original owner fashioned his own light-weight electric Jackplate using a Lenco actuator.
Neither is the factory PT assembly that came on those Tohatsu/Merc/Nissan 20hp models. It's tilt ONLY, will not trim with any more than about 1/4 throttle.
