question about my motor.
florence, al
i was thinking about making a center console for my 14 ft flatbottom. its a 25 hp electric start motor with a tiller handle. is it possible to run the wires from that motor to the throttle and steering wheel since its electric start or do i need another motor?
No need for another engine. You can extend the leads from the stop switch easily but to do the starter switch you may have to add a solenoid if the engine is not equipped with one. Am thinking it is though. If so then just run parallel circuits rather than one long series circuit that way either switch will work.
